Greetings from Northern California
simon
Hi guys and girls,
I'm new to the forum and wanted to introduce myself. I'm Simon, from San Jose CA (originally from the UK) and I'm a complete beginner.
Last year I decided it would be interesting to see if I could learn to dismantle, clean and reassemble a watch movement. Since then I have spent countless hours reading forums, websites and watching youtube videos to try and pick up the basics. I decided a Seiko automatic movement was a good starting point as they appear to be pretty well documented, have a good knowledge base and have a reasonable availability of parts. I ended up picking up a cheap, semi-functioning Seiko 5 on eBay as my first practice watch. (semi-functioning in that the watch runs but the minute hand doesn't move). It turns out it's a 5126A movement, which actually doesn't seem very well documented, but the 5106 tech manual and oiling instructions (which I found through this forum) look enough to get me through.
Anyway, it's all stripped down and sorted into parts trays and I didn't break or lose anything, so that's a good start!
Next up is cleaning, then the difficult part of putting it all back together! I'm sure I'll have questions and newbie tales of breaking things though inexperience and stupidity, but that all part of learning, right?
Cheers,
Simon.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
