Dear friends,
Very eager to service my Zenith 2572c, but I am stuck with a very silly issue of non-working stem release button.
It appears to be a simple push to release type, but it doesn't release the stem when the pressure is applied.
What could be the possible solutions? Getting to the keyless works would be brilliant, but I can't reach it without removing the bloody stem.
Thank you kindly.
Sounds like you've already tried the correct approach but humour me and, pull the stem/crown out to its outer (time changing position). Now applying constant moderate pulling pressure on the crown (perhaps with the thumb and third finger of your right hand) depress the stem release button with a suitable tool held in your left hand.
If this doesn't work them remove the movement retaining ring (two screws hold it in place at 12 and just after 6 o'clock positions in your photo) as this will give the movement a little more freedom in case there is unexpected resistance on the stem that is causing an issue; repeat the above.
Still no luck? You've little choice but to remove the barrel bridge so you can get an indication of what's going on underneath it and get a glimpse of the stem release button and keyless works. This is straightforward though. You should already have ensured the mainspring is wound down after which this is just a case of taking off the two wheels atop the bridge (crown and ratchet) and the three screws that hold the bridge in place. Now you can remove the bridge and see what's going on:
Let us know how you get on!
Edited by WatchMaker
I take this gorgeous creature to a zenith master with no less than thirty years experience and gladly pay the expenses. You will still have plenty money left to buy a regular watch to work on. This way you got better chance of showing off the gorgeous on the forum and lets enjoy watching it. Rather than asking this:hair: guy to express your regret.
Good luck pal.
Appreciate the detailed and valuable advice, Sir.
In the end, after taking off the barrel bridge I found the stem release mechanism to be damaged. Managed to reach it at the side of the stem and the stem/crown were released.
A pleasure to resolve the issue, but the search for the part begins.
Thank you for all who tuned in!
Good luck pal.
I didn't start this hobby to give up on a challenge, although I am sure I will pay a dear price some day. Thanks for advice.
    • Hi all, Might a posit a theory and people can chime in and tell me if I'm barking up the wrong sycamore: If a mainspring is a bit coned and returned to its barrel for reuse, is it less likely to slip when the spring gets to fully wound?  For a bit of background: Slava 2427, barrel walls greased with 8217, six dots evenly spaced around each of the barrel walls, then smeared/ spread along the wall before popping the springs in.
    • What kind of screwplate are you using? The old Martin ones commonly came in B and L variants. The thread pitch is slightly different between the two, and the full thread diameters tend to be a little off from metric nominal, but the B plates are close enough to metric that they work most of the time. The numbering follows (pretty much) the numbering for stems- at least how stems threads are commonly called out. So a "tap 12" would be 0.70mm. (I can only guess the "tap" size for stems comes from these old plates)   These old plates tend to cut some and also form the thread by displacing metal. I think in part because they are low-tech, and also generally a bit worn. So it's good to start quite undersize with your initial diameter, and work up to something that gives a full thread form. There are variances plate to plate too, most likely a combination of manufacturing differences and wear.   I haven't tried any modern screw plates, I think they are of questionable origin, and even if marked in metric, probably merit some experimentation like the antique ones to find a good starting diameter.
    • Exactly. As Richard says, all good - I helped you by splitting your comment made on an old topic into a new topic of your own in order to help with clarity 🙂 Welcome to the forum by the way 👍
    • Mark, means he has made this a separate post, he has split it from the old post. You don't need to start a new thread now.
    • No, my first time. I've watched the video, lets hope it looks as good as yours.
