French brass/silver guilloche desk clock problem
cduke
Hello,
I have a vintage French brass and silver guilloche desk/travel clock - 8 day- that has a broken hand stem (shaft). It was given to me in pieces.  The back of the clock where the hands could be turned has a round brass knob that was screwed onto the end of the shaft. This know has snapped close  (about 3mm from the end.  Is there any way to repair this part or is it a matter of trying to find another part off of another vintage clock. Ugh!  The clock seems to run fine but the clock hands cannot be manipulated without removing the glass face.  I will try to post a few photos soon.
Thank you
Edited by cduke
6 hours ago, nickelsilver said:
Can you post a pic of the broken part? Normally it can be drilled and repaired.
Sorry for the quality but you get the idea.  I assume it may be possible to drill a stem into one end of the shaft and a sleeve in the other?  Is there a better way to mend these pieces?
Thank you
2 hours ago, nickelsilver said:
Hard to really see but yes, should be doable.
Thanks.  I presently do not own a micro drill. Can you recommend a tool for this purpose?  It seems like a hand micro drill would not be sufficient to drill into the shaft.  It appears to be a gritty composite metal.
This is most definitely lathe work, and probably not the best to start out on. French arbors are notoriously hard, the gritty surface is the grain structure of the fractured steel. It's not a composite metal, just good old high carbon steel, hardened and tempered. If I was doing this I would stone back the rough surface in the lathe, then drill with a carbide drill. Back in the day they would harden the (steel) drill in mercury to get it hard enough to cut these, thankfully we have modern materials like carbide now.
Thanks.  My area seems devoid of capable clock/watchsmiths so sadly it will stay broken for the foreseeable future.  All the good ones have retired or passed on.  A dying art in the age of quartz mechanisms and electronics.  I don't think it is that valuable so it is not a tragedy just a shame.
On 11/7/2018 at 4:13 PM, oldhippy said:
Is it possible that the center shaft can be knocked out with a mallet or nylon hammer. If so it would be easier to make a new complete shaft. Far easier then drill and tap.
I think it could be removed in this manner.  I need to research a clockmaker who could do this work and let them decide.  I am not equipped in skill or with tools to do this kind of work.
Thanks for your input!
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
