Citizen Eco-Drive Chronograph
WillFly
I've been after a solar-powered chronograph for some time, but they don't come cheap (I like solar power). Anyway, I managed to get this from a chap on another forum at a reasonable price, so it's up to the music room with it...
I would say it looks like a cross between nice and beautiful, congratulations on your new, gorgeous watch Will!... and good durable brand.
By the way, what's the model?
The movement calibre is an E 210, and the model is a Citizen AV0031 59A.
I managed to source some extra links for this watch. I knew when I bought it that it wouldn't fit my wrist, but was OK with that because I intended to use it for music timing purposes with it sitting on a desk. But, by chance, I spotted some spare links for this model on a US eBay Buy-It-Now sale - so bought them. They came this morning, I fiitted two of the three spare links in just now, and it looks fine. Feels good too. Some chunky watches (this is 44mm) can look huge on the wrist, depending on design - other don't "wear" as big as they are. and vice versa for small dials... Any, 'yer 'tis:
Edited by WillFly
    • Surely it depends on the clock , I only usually restore torsion clocks and I only use oil on mainspring ( small amount) but on the few so called normal pendulum clocks I have done I have used mainspring grease as there is more reserves of power than there is in a torsion clock so it is not so critical. Dell
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
