Stem Removal on Sellita SW200-1
Trying my first watch build and cant figure out how to release the stem on a Sellita SW200-1 movement.  Reference material from Sellita shows a diagram of a bridge cutout and a part, I believe was the setting lever but am not sure of the correct way to remove the stem.  Any help would be appreciated
Use the largest tip screw driver which gets in the oval hole. The tip is be wider than diametet of release button and enters cross to the STEM AXIS, a shoulder is provided inside the hole to stop the screwdriver tip from insertion deeper in. Pushed in down to the shoulder which is enough to leave the stem free to be taken out. If not clear let m know to hand draw you a sketch showing what I say.
Regqrds joe
Yes, thanks to OH , the picture shows the push button.
The hole as viewed from top is not circulare but parabollic.
The screwdriver blade should be wider than diameter of  the button, so not to enter the button hole, rather enter the parobollic hole only and go down as far as the parrabolla hole provides depth,  the shoulder inside keeps the screwdriver from entering button hole only if the screwdriver blade is wider than button hole.
Sorry to post a n00b question, but it's somewhat related...
After you put the hands back on the watch how do you remove the stem (in order to put it in the case)? Is it ok to put the face down on the Movement Cushion Pad, I'm worried that doing that may bend the hands or something?
You risk damaging the dial plate too. Dial should not be subjected to any stress.
If your movement holder blocks access to the back of the movement , perhaps tranferring the movement on another holder which allows such access is considerable.
I have managed sliding  the movement in the case at oblique angle,  with crown removed from the stem. Once movement is in place in the case, remove the stem to tighten the crown back on stem and reinsert in the movement. Easier done than said.
Picture of the predicament you got in helps.
Regards joe
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
