Hi everyone, I serviced a Navitimer about one year ago for a retired commercial pilot friend. Then another one came in for service with sweep hand fallen off,  then a good quartz copy arrived (Ronda asservicement movement) One broken pusher and I had one that fitted fine. 9AM this morning a tel call to ask me to service/repair another one. What a run !!!! ????
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
