I've had some fun since yesterday hunting down parts for a 1945 Bulova 10BAC movement which I've started looking into repairing/restoring. The third wheel was missing and the tension springs were too. Picked it up for a reasonably low price so there's room in the budget! Unfortunately, after looking up the darn thing in the 1952 bulova interchangeable parts catelog, it's one of those unique movements which doesn't share a lot of parts with any other movements so you literally must have either another 10BAC movement or a NOS supply, so I ended up locating the one and only Google findable #91 Upper C.S. Third Wheel on Ofrei.com which also had the tension springs in stock.
I'll also need a new crystal, sweep seconds hand, correct crown for this model and a nice strap. Appears to have been a real production model at the time but model name is unknown. Too small to be a military style watch though the dial still suggests an air navigation origin.
I spent hours yesterday running down options for this, and several other Bulova watches. It's fun in a way. Anyone else sinking ridiculous hours into parts finding?
Here's a complete one in excellent condition from http://www.mybulova.com/watches/1945-unknown-4206 :
CloseCopy.jpg?1334077232LargeMovement.jpg?1334077462
Let's say mine is a slightly less clean though the dial looks perfectly fine and the blued hands are intact and clean ;).
I have couple watches that have taken months to source parts for. I find this part of the hobby as much fun as building the movement. I'm about to put a TAG F1 chronograph back together shortly, it's taken eighteen months to source all the parts that I wanted to replace.
I've tended to try and source whole movements. I found an Enicar 1292 complete, working movement, for my Majex - much easier than sourcing the one part I needed. £26 from the US, plus minimal postage - and I have a spare movement... I've done the same with my Unitas 173 movement, for which only a replacement equivalent mainspring is available on Cousins.
Got an old Omega 19''', 2 years on still looking for a for a replacement balance or roller jewel. As for the rest (early Seikos + odd swiss from the 40/50/60's) no big problems.... so far.
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
