A few weeks ago I posted asking about where to get replacement hands that would match my Rolex dial so here it is:
I ended up going to TWBG to have the hands replaced with Rolex factory white gold hands and have both those and the new dial installed which totaled $215 including 2 day UPS insured shipping both ways. The hands were $120 and it was $50 to have them and the dial installed. Unfortunately, the old hands on the watch had to be sent back to Rolex to be lost forever but its just a Datejust and finding some no lume hands in good condition shouldn't be that hard should I decide to switch back, Im fairly certain I won't though. TWBG did a good job at a fair price but the communication was lacking but I understand that this job was probably their lowest priority. And some pictures:QacGw1E.jpgM0w5VMl.jpg57ENXjq.jpg
Rolex are beautifully crafted fitted with superb movements. The downside is they are expensive when genuine replacement parts are required.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
