So i just picked up a stunning old Tudor, minus the crown! I believe this has the ETA 2750 movement.
The stem seems quite short to me. Fitting another crown there is not enough "travel" to fully insert them stem when it's re cased. So I'm thinking the old crown may have snapped off?
Anyway, main problem - buggered if I can get the stem out! I assume it's the little button near the stem but pushing on it won't release it and I'm terrified of pushing too hard and pushing the button out the dial side.
Any ideas please?!? Am I heading in the right direction with that being the correct stem removal procedure?
Ta, Matt
You won't push the button out dialside as there are parts over it. But you could disengage parts in the keyless work so it's gets hard to put the stem back into place again. It's the right button so need to press on it to get the stem out. If it doesn't work take the hands and dial of.
Edited by rogart63
Thanks for this. Ok, odd, using a flat blade screwdriver I can actually feel the button depressing but the stem will....not release. I wonder if there's a problem somewhere within?
Choose the LARGEST HEAD screwdriver to go through the hole B-B, push down on the button as you like, the screwdriver stops at a point, by a step, provided as the diameter of the hole A-A  the button is in, is smaller. The step is as deep down the botton is to go to release the stem.
The key to proper, risk free operation is the SIZE of the scrwdrivers head, to be larger than the diameter of the small holeA-A,  just so it can,t get inside the smaller diameter hole.
Regards
Modified to show the screwdriver head/tip.
You can work with a smaller screwdriver or any tool, as long as, it dosn,t enter the smaller hole.
In case the stem dosn,t want to come out, rotate them stem, a slight pull wont hurt.
Keep us posted please.
Regards
Goodness! That's what I call a thorough response. With diagrams no less! Outstanding sir :)
I'll have another look later and see where we are.  Thanks so much.
I fell in love with this tudor.
Getting  charged a fortune on one hand and risk getting this beauty damaged. So I suggest do not use a flat blade screwdriver, but a round bar, hard strong polymer stick, it would be worth the trouble of cutting one out for the job. Polymers wont scratch the surface.
Once the button is pushed as far down as the designers calculated, you may need to push/pull the stem in and out, turning the crown can help.
Though stem extender is normally used, you wouldn,t want anything less than perfect for such a jewel.
Rdgards
Rdgards
Thanks also for this, much appreciated.
As you seem to be a fellow fan, here's a couple of pics of it cleaned up, screwed together with a temporary crown on it. It's a beauty.
There's a slim chance of me conceding on this one and taking it to my watch guy, in part for some of the reasons mentioned in this thread!!
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
