Looking for glass
margolisd
Hi all. Does anybody know where I might find a replacement plastic snap-in glass with this profile? The outside diameter is 316. I've been through the Sternkreuz catalogue and the closest I can find is X316.007. I ordered it but it doesn't look quite right. It has a step above the flared out bottom and is also too proud.
It's from a special addition Longines (I posted about it a while ago). Any advice appreciated. I've never replaced glass before so a bit confused.
Cheers
Should you like to make use of the crystal you got, you can gradually and EVENLY shave off of the flared bottom, using a sharp edge of a broken piece of glass, razor or even a sharp knife, at 45 degree angle or so, this would let the flared bottom insert in.
You would want to shave gradually to avoid shaving off too much and check the fittness as you go.apply little pressure, go around the circumference evenly.
Practice on a useless cryatal to get the hang of it.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
