I came across this Optel LCD listed as a parts repairs.  First step was to check all the solder joints, and next to clean the display contacts with electronic cleaner.
It didn't seem to do anything but while sitting on the bench about a week now I do see the display will fade in and out some.  My guess is the display is bad and will have to be replaced with one from a donor.  Anyone here ever work on one of these?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
