Shortt–Synchronome clock
Tmuir
The Perth Observatory has in their possession a Shortt–Synchronome clock, this clock used to be the clock that provided the time for Western Australia.
For those that have never heard of it, this is the most accurate pendulum clock ever made. When it was made in the 1920s and 30s it was believed to have an error of 1 second a year, but in 1984 one of these clocks was compared to an atomic clock and found to have an error of only 1 second every 12 years.
It achieves this by having 2 pendulums, one that swings in a vacuum which is the master and via magnetic sensors it sends pulses to a slave clock that displays the time.
I was just wondering is anyone here ever has had the chance to see or touch one of these clocks?
Currently the observatory is looking to get this repaired, I have no involvement in this, but I do know people that are tendering to repair the clock and should they be successful I will be asking if I can atleast come up and see the clock whilst they service it. Just stressing I won't be working on the clock, but to get a chance to see a clock like this serviced would be too good an opportunity to miss.
For those that would like to do some more reading on this clock it has a wiki page.
https://en.wikipedia.org/wiki/Shortt–Synchronome_clock
I have seen them before there are various ones on display in museums in the U.K, I have seen one at the Greenwich Observatory and the science museum has one in its collection and quite surprisingly they do turn up in auctions I have a Christies catalogue for a specialist horology sale in which one is listed.
As for touching one I always heed the signs that say "Do not touch the exhibits":)
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
