Help identifying movements
I don't normally touch other peoples' watches but on this occasion a good friend asked if I could have a look at 2 of his 50 year old watches and hopefully improve them.  Both dials and movements are signed Winegartens and one case has Dennisons stamped inside the back.  Both movements run quite well despite never having been serviced.  If possible I would like to find service documentation for these but of course I need to know something about the movements first.  Can anyone help me to identify them please?
No idea regarding movements.
A watch is a watch. You can strip them down to parts, photograph the order. Clean in hot water and ammonia, then dip in shellite.
Black Moebius grease for barrel and mainspring. Moebius 8000 for slow moving parts and 9010 for fast moving parts like escape wheel.
Pallet lever doesnt require oil usually. 9010 on both ends of balance staff. I usually put a bit of oil on tip of screwholes to prevent seizing.
There is nothing else to it for older watches, you won't find obscure service guides unless they are ETA, Omega, Rolex, or similar movements.
The main thing is strict cleanliness and robust cleaning technique,
Newer more high performance watches require adherence to service charts for optimum performance between service.
An ETA 2836 for example will benefit from correct grease to pallet jewels, high speed oil for high speed parts. Correct grease/oils in keyless and date mechanism. Mainspring either gets grease or no grease depending on the watchmaker (I use grease).
Chronographs again require more thought for moving parts.
A good start is to google "Moebius Oil chart for watch movements" - it goes through different size movements and oil recommendations.
When I started with cheap watches such as the ones you posted, I only used Moebius 8000 as it was cheap and fits all purpose. Service interval atleast 2 years (many watches still running to spec with 8000).
I'd soak the cases in ammonia and water to remove sediment, then polish gently by hand with Autosol or a buffing compound.
The crystals will need soak in above to remove crud, then sand with 400/800/1200/1500/2000 (wet sand) and then polish with PolyWatch (found on eBay).
The best way to glue them back in is with GS Crystal glue (ebay as well).
Straps are either ebay or Cousins (the open ended ones for the 2nd watch can be hard to find, ebay is okay - look for "open ended leather strap").
Feel free to ask more  questions.
Edited by AlexeiJ1
Winegartens with some watches used AS movements. If you are able to remove both from there cases, then remove the balance complete. You might find some ID around the balance area. If not, then remove the hands and dial, see if the I D is there. If nothing then take good clear photos showing the keyless work. That is how we I D movements.
Thanks for your help, with which I think I can answer my own question - though confirmation from the experts would be nice!
The square gold watch has a symbol under the balance with a "P" in it and "330" underneath, which I think might be Peseux.  The SS watch has a symbol under the dial "FEF 190".  Fleurier perhaps?  A shot of the keyless works for the FEF 190 is included for info.
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
