I'm currently reading Anthony Whiten's watch and clock repair and it is truly a treasure trove of knowledge and help.
This page was of great interest and i figured for those who maybe cannot afford all the razamataz that is required for this hobby/job this would help. I've never heard of making Rodico out of bread but what do you know. I haven't actually tried it yet but I'm going to. 5efdcaa2069943087497563afc52211a.jpg
Sent from my Z956 using Tapatalk
If you watch the Hamilton factory movie on YT there is a sequence where the big mass of dough made fresh every day is shown.
Ah, I remember reading that somewhere as well. Great to dab away the excess whale oil!
Terrible idea in the modern age where a pack of rodico costs just a few bucks and lasts for ages..
    • Many thanks for your answers: 1. I will clean both of them without risk 🙂 2. Both of the rotate inside their setting but they don't seem to come out. I will clean the cock (and the hole jewels) and I will see if they want to go out. I don't intend to force the setting pushing it out by any means. I only hope I don't need the dismantle the whole cock into all its components...! 3. I won't touch it. Only clean. I don't want to take risk... Thanks again!
    • By worn pivot, Do you mean short ?   A pivot is not short if balance spins freely on it. Dial up & dial down tests are good test for investigation, visual test alone doesn't suffice. A thorough test is free oscilation, which is best done when balance cock is adjusted with acceptable end shake. Balance settings on both side should be dismantled as they must be cleaned, pegged and inspected.  Regs
    • 1. I think the pivots look pretty good and I wouldn't worry about wear. 2. Yes, I think the hole jewels should come out for cleaning, complete with their spring setting. I don't have experience with Rolex but I've seen this spring type setting in another movement. They may be stuck in with old dried oil. 3. Yes, I think the overcoil is out of shape.
    • Yes, I'm looking at this option. I have a good friend from childhood who happens to be a goldsmith, and he would certainly be able to tackle the second hole to my specifications. I usually avoid this path because, since he deals with gold pieces, every time he stops to help me with "frugal" parts, he is objectively losing money. I agree with you. Even though I couldn't justify paying this much for the set (they only sell the whole set or the sole case tube), I understand the price tag. The trouble with this particular stem set is that the most common use case for it is the Technos Skydiver, a watch whose price certainly justifies 220 USD for a brand-new stem set.   I have messaged them only on the surface, without specifying my needs. They already stated that they don't sell the single female part, only the full set. What I still don't get is the need for a second hole. Is it supposed to be some sort of regulation, meaning that I can fit the head of the male part in any of the two holes to adjust the pressure of the spring? Does this mean that a single-hole female part has a chance to work with my setup? I'll later test this hypothesis while continuing the assembly of the movement. Some photos are attached. Can you judge this bracelet? It was dirt cheap (4 USD), genuine leather, wife's choice. I have just realized my dial is upside down. lol
    • Hello from chilly Brazil! I just bought a couple of watches and this watch came with them. While perhaps not worth much I'd like to try to find out something about it. Googling comes up with with the name Gerald Genta, and I see from internet searches he's made some nice designs (perhaps an understatement)! Also some cartoon designs but I can't find anything like this anywhere, so most likely not his!  Googling Royama I see that some famous people liked his watches and also the Royama watches. Two questions; 1. Can anybody tell me anything about this watch and its background? 2. How to get the base off to let down the main spring which is fully wound. I gently tried prying it but nothing, I see there is a button but have no idea if it is functional for removing the back or anything else. Screwed back maybe? I really don't want to break the back or the watch with too much pressure and haven't looked up the properties of Grilamid!   Probably not much of a watch but it peaked my curiosity and I hope somebody might be able to help? The auctioneer sold it as a psychedelic acrylic 1960/70 Royama watch overwound! All the best...Jules
