Does anyone know how to removimag1566-jpg.481164e the cap jewel from a Hamilton 747 balance? Im thinking you have to remove the stripguard, but not 100% sure.
Thats what I thought too kinda like a Kif spring, but it wont move. Not sure I'm trying as hard because I wasn't 100% sure I was suppose to move it. Any recommendations as to what you would use to remove it? Thanks
I had the same thoughts myself and did try that, but i think i was being too careful not to break it, but im going to give it one more try. Thanks for the help i appreciate it.
Maybe better to leave as is. And clean it in the ultrasonic as is and then oil . Should be fine. Could be hard to find a new part if it breaks?
I did clean and oil it, but im experiencing some issues with the watch that I believe, not removing the cap jewel, is causing it.
Okay. Could maybe be some thick old oil under there . Not sure how to remove. Maybe you need to make some tool that goes down on the side of  the jewel.
So I solved this issue, someone sent me the hamilton 747 service bulletin and it says to put a screw driver in the slot and turn counter clockwise and it will release the cap jewel. I did it last night and it worked so problem solved.
Thought you had already tried that :) But happy you worked it out.
