Fuddy Duddy Watchmaker
My wife threatened to buy me this http://www.ebay.co.uk/itm/Kay-Kyser-The-Fuddy-Duddy-Watchmaker-Lets-Get-Lost-78-Columbia-36673-TESTED-/121449332883?pt=Music_on_Vinyl&hash=item1c46f1c093 last night. Having listened to the words carefully, I don't know whether to take it as a compliment or not!
Listen here:- http://m.youtube.com/watch?v=8118Nte2k1c :-)
well at least it swings!
    • Back home...printing now.  Will report results
