Connecting Stem to Crown problem
I am fitting a Miyota movement 2117 to an old watch case, and wish to use the old crown. Problem: The 2117 includes a stem with tube of (Standard) 0,90 ext diamter, but the crown must be fitted to a 1,10 mm ext diameter stem. How to do this?
Normally there is this thing called a stem extension. You can get one that is 1,1mm on one end and 0,9mm on the other end.
The problem is that, as far as I know, it would only work on really long stems, otherwise you wouldn't have enough room to fit it. This also requires that you cut the original stem...
WATCH-STEM-EXTENDERS-EXTENSIONS-70-90-TA
Esslinger have 0.9/1.10 stem extensions ... They call that "stem extenders".
I think it would be better to cut the extension first, short enough so that the 0.9 connector is as close to the crown as possible, then cut the 0.9 stem to the right length.
That's the way I do and I've never had any problem.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
    • Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge. Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
