Got this Omega from the sales corner on Rlt being sold for repair ,the spring was slipping and the second hand was missing , crystal cracked and a bit grubby.
So stripped it ,cleaned dial with a good old drop of saliva , fitted new mainspring as the tail end had broken off causing it to slip , cleaned and lubed movement , a 268 17 jewel manual dating at 1960 , found a new second hand from a donor watch fitted new crystal and here she is.
It's never going to be a safe queen as the plating is a bit shabby and the dial isn't perfect by any means but it's a wearable vintage piece hopefully.
Been running now for almost 24hrs and is keeping good time , which is always a bonus
It's 1964 - Cal. 601. You can't tell from the photo, but there's quite a bit of plate loss from the upper part of the bezel. It hardly shows, but I may yet swap it for a similar one with a better condition case.
Or just buy another, of course... :crazysmile:
Sounds like a plan Will just buy another lol.
I have a steel seamaster with a 601 movement from 1967 it was one of the first i got
Edited by Andyclient
Thought you could only use spit and polish with boots but that is quite an appreciable difference on the dial.
Wiki says saliva is 99.5% water, while the other 0.5% consists of electrolytes, mucus, glycoproteins, enzymes, and antibacterial compounds such as secretory IgA and lysozyme.
Wonder if the water did the job or the special mix in the other .5% either way it worked. Outstanding job.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
