I've got a Seiko 5 watch that I recently restored the case is 7019-8180, but the original movement has been swapped out for what I think is a Seiko 7S26 movement.
The oscillating weight needs replacing on this movement, but as it does not have its calibre number on it I cant work out if its a 7S26A, B or 7S26C and I believe they all use different oscillating weights.
If anyone can tell me what to look for to ID the movement that would be great.
A couple of pictures of the movement below,  if you need any photos of other parts let me know.
I take no responsibility for the marks on the movement, its how I found it, but after servicing it is running with 0.0 beat error and an amplitude around 280 degrees and acuracy of around +15 - 20 seconds a day between dial up and dial down
I think I have managed to answer my own question, but would like confirmation.
My movement oscillating weight is a quarter rather than half circle which I think makes it an 'A'.
Can someone confirm that?
As mentioned already in similar topics, the weights are all interchangeable, no matter their shape or marking, and so are most other parts. The most notable evolution is Etachron introduced in B version, and calendar plate with 4 same flat screws in C version.
For a detailed list of parts interchangeability, check the table that I maintain at https://docs.google.com/spreadsheets/d/e/2PACX-1vRN2UULQKTfKmhRStZhDdIOIQrqd6sPB-g6x2SKyQQjOvTBjG_7TQXQhAT4f1WqAX5QAPkIimi-3jqd/pubhtml
Thanks for that.
I've downloaded your document and added the oscillating weight to my Cousins order which I will be placing later tonight.
3 minutes ago, Tmuir said:
Thanks for that.
I've found Speedtimerkollektion useful for cheap Seiko parts
Just PM with your address, I have many to spare.
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
