There isn’t supposed to be a spring. From the photo you need to turn the ratchet wheel over. That little pin is meant to go through the arbor to hold the ratchet wheel in place, I would replace the pin because they are not supposed to come out (it is what I call ill fitting)
Thank you. This is becoming a lot clearer now. So the ratchet wheel is pinned to the arbor and when pretension is applied, the ratchet is swung into place and locked off with the screw, thus preventing the pretension being lost. All I need to do now is reassemble the chain and setup the pretension. Kind regards Deggsie
I fiddled with one of these some time ago and unfortunately broke a lever pivot when re-assembling so will need to get a new staff/pivot made by a professional watchmaker (about £30 last quote!!).  This was caused by trying to get all the pivots into the large single plate.  Make sure the plate sits down easily on the posts before you start to re-assemble the train as this can make pivot alignment difficult if the plate is tight on the posts.  I think the ratchet is only for when you are finally setting the winding of the chain on the fusee to give it a little pre-tension.  There are several good books on English Lever Full Plate Pocket watches which I consulted.  I copied the relevant pages for my file but didn't make a note of the authors (duh!!), I thin one was by DeCarle, but if you search the net for English lever Full Plate Pocket Watch repair/restoration you may find good info on how to check/repair the fusee, assemble and set-up the watch etc.
  On 4/2/2018 at 8:03 PM, Deggsy said:
And here are the photos. Sorry, I got Freddy fast fingers today
ecdac79558c739e202402b366f9a162e.jpg&key=fa90dfa4d595826d149c03f39aed94d7944f2e8f5a7f26f34989dcbfc01e882148f528014b79ea8a2be9fddd304bb56e.jpg&key=2b1d7e9f6a1e280ef86246e93f5d8ebdffa85bc2833c8a63334eb8eb3b2fd94e
Make sure you turn the ratchet wheel about 6 clicks to put some tension on the spring elts the chain will drop off...
Hello OH. Sorry not to have reported back on this for a few days but work has prevailed (unfortunately). The square end of the mainspring arbor does not have a hole through it. You explanation seems so logical. I’ve looked at 20x magnification on all 4 facets and no evidence of a pin ‘sheared’ off either. So I’m wondering do some designs rely on the mechanical back pressure on the ratchet to lock it onto the square arbor?
Also the chain is quite stiff so I need to but some work into this before going any further. It’s soaking in white spirit just now, then I shall soak in naphtha, and finally warm 3 in 1 oil.
I’ll keep you appraised of how things go. Any comments are much appreciated as this is my first fusee p/w
Yes that is correct.
[emoji106][emoji6]... thanks
Well, I'm sitting on the edge of my chair waiting to see the end results of this endeavor! Fantastic work thus far! This is why I love this group!
Ah .. Gary you may need to sit back and relax for a bit as things have taken an undesirable course. Sadly the barrel hook had become detached from the chain! Under microscope it appears that a solder joint may have been made in the past. The good news is that replacements seem to be readily available on eBay, although I need to measure up the exact length, width and thickness. The chain I have is very worn down the sides of the plates do ascertaining the true thickness may be difficult. These things are sent to test us!
In not sure if anyone here offers a repair service? Or maybe you know of someone who can?
Regards
Deggsie
Just to give you all an update on this repair. Firstly thank you to all who have offered positive and useful advice, especially OldHippie. Without the advice I have received on here I would not have started this project. I’m currently sourcing a replacement fusee chain from a gentleman on eBay who literally has too many lengths and sizes of chains to list then all, so I’m hopeful he can find one.
I’ll keep you posted when I have a replacement fusee chain and have it installed back in the watch. Until then, onto my next movement
Deggsie
    • It might be the arbor of one of the train wheels slipping. Remove the balance wheel but leave the pallet fork in place and wind until there is slippage. Obseve which wheels turn and which wheels don't.  And yes, the most obvious. Is the mainspring wound in the correct direction?
    • This is a positive development, especially if it holds in both horizontal positions.
    • Good question. I went back and checked, and it looked like it had been reduced, but not as much as I had hoped. So I took off the balance assembly, removed the hairspring, mounted bridge, tried to bend some more, then retested. Not much change, again. I did that five more times, each time trying to apply more force. There’s now less end shake, but I’m reluctant to push it much more. As you pointed out, these bridges are surprisingly strong, thus hard to bend, thus hard to control how much force I’m applying beyond a certain point.  In the free oscillation test, I’m now up over a minute (sans shim), which is getting us back towards where we started before embarking on the exercises of oiling and bending.
    • Yeah ok, probably is the escape wheel. Yep, that part worked ok before I worked on it. Yes I did do this, but something must have slipped past my eye, train of wheels was smooth, pallet fork snapped, and balance pivoted freely.   Thanks for your help everyone, hopefully this week I'll have time to sort it out.
    • The watch was a non-runner when I was asked to look at it. I'm not able to say if its components are all original. Thank you for taking the trouble to dig out the thread which I found very informative. I thought I should try to find some details about the watch that way rather than just rely on the good people here who have already helpfully answered my original question viz: are roller tables traditionally a friction fit. I'm sorry if my previous posts have caused confusion. I don't charge the Charity Shop for my time or materials so neither "lowest price" nor "profit" is relevant. I will tell the shop to what condition I have been able to return the watch & advise whether I think they could hope to get a better price online rather than selling locally in declaring that condition. Naturally I aim to do work that is 'proper' - hence my question that initiated this thread - or at least reversible & explain what I have done & why. So "fast quick repairs" doesn't exactly apply either although I won't hold on to a watch beyond the point at which I'm making improvements or have the realistic prospect of doing so, for example as a result of advice I hope to receive from WRT colleagues. I do hope this clarification is helpful. Thank you for your interest.
