H.J. Norris (Coventry) Pocket Watch
There isn’t supposed to be a spring. From the photo you need to turn the ratchet wheel over. That little pin is meant to go through the arbor to hold the ratchet wheel in place, I would replace the pin because they are not supposed to come out (it is what I call ill fitting)
Thank you. This is becoming a lot clearer now. So the ratchet wheel is pinned to the arbor and when pretension is applied, the ratchet is swung into place and locked off with the screw, thus preventing the pretension being lost. All I need to do now is reassemble the chain and setup the pretension. Kind regards Deggsie
I fiddled with one of these some time ago and unfortunately broke a lever pivot when re-assembling so will need to get a new staff/pivot made by a professional watchmaker (about £30 last quote!!).  This was caused by trying to get all the pivots into the large single plate.  Make sure the plate sits down easily on the posts before you start to re-assemble the train as this can make pivot alignment difficult if the plate is tight on the posts.  I think the ratchet is only for when you are finally setting the winding of the chain on the fusee to give it a little pre-tension.  There are several good books on English Lever Full Plate Pocket watches which I consulted.  I copied the relevant pages for my file but didn't make a note of the authors (duh!!), I thin one was by DeCarle, but if you search the net for English lever Full Plate Pocket Watch repair/restoration you may find good info on how to check/repair the fusee, assemble and set-up the watch etc.
And here are the photos. Sorry, I got Freddy fast fingers today
ecdac79558c739e202402b366f9a162e.jpg&key=fa90dfa4d595826d149c03f39aed94d7944f2e8f5a7f26f34989dcbfc01e882148f528014b79ea8a2be9fddd304bb56e.jpg&key=2b1d7e9f6a1e280ef86246e93f5d8ebdffa85bc2833c8a63334eb8eb3b2fd94e
Make sure you turn the ratchet wheel about 6 clicks to put some tension on the spring elts the chain will drop off...
Hello OH. Sorry not to have reported back on this for a few days but work has prevailed (unfortunately). The square end of the mainspring arbor does not have a hole through it. You explanation seems so logical. I’ve looked at 20x magnification on all 4 facets and no evidence of a pin ‘sheared’ off either. So I’m wondering do some designs rely on the mechanical back pressure on the ratchet to lock it onto the square arbor?
Also the chain is quite stiff so I need to but some work into this before going any further. It’s soaking in white spirit just now, then I shall soak in naphtha, and finally warm 3 in 1 oil.
I’ll keep you appraised of how things go. Any comments are much appreciated as this is my first fusee p/w
Well, I'm sitting on the edge of my chair waiting to see the end results of this endeavor! Fantastic work thus far! This is why I love this group!
Ah .. Gary you may need to sit back and relax for a bit as things have taken an undesirable course. Sadly the barrel hook had become detached from the chain! Under microscope it appears that a solder joint may have been made in the past. The good news is that replacements seem to be readily available on eBay, although I need to measure up the exact length, width and thickness. The chain I have is very worn down the sides of the plates do ascertaining the true thickness may be difficult. These things are sent to test us!
In not sure if anyone here offers a repair service? Or maybe you know of someone who can?
Regards
Deggsie
Just to give you all an update on this repair. Firstly thank you to all who have offered positive and useful advice, especially OldHippie. Without the advice I have received on here I would not have started this project. I’m currently sourcing a replacement fusee chain from a gentleman on eBay who literally has too many lengths and sizes of chains to list then all, so I’m hopeful he can find one.
I’ll keep you posted when I have a replacement fusee chain and have it installed back in the watch. Until then, onto my next movement
Deggsie
    • I think from my own findings and what has been said here that I'll switch to naphtha as my post-pegging solvent, its also more compatible with my watch cleaning chemicals too. Making a new batch of watch cleaning solution and rinse solutions this weekend!
    • Interesting! Thanks for sharing this. I wonder, though, if the substances evaporate in similar quantities. What I mean is: let's say, if we open one container with acetone and one with naphtha for 10 seconds each. How many PPM's of each would go into the air for us to breathe in? Hypothetically, if acetone (1000ppm OSHA limit) evaporates 10 times faster than naphtha (100ppm OSHA limit), then they'd actually be equivalent in practical use. Anyways... if feel relatively safe with these solvents because I only open the jars very briefly and close immediate + I always open the windows wide when I do anything with these solvents.
    • No need to doubt, You have received the wrong stone. 120 is 120 and will allways measure 120 as out diameter. What You did wrong is that You reamed the hole to 119, believing that this is the right way to fit new jewel there. Actually, the original jewel was rolled there and the hole and surrounding place has dedicated shape, and there often is no enough 'meat' to ream the hole and have normal walls as result, that will hold the pressed new type of stone right.  Often the decision is to ream enough so the surrounding of the hole is gone and make a bush that fits in this new hole, and the bush internal hole will take the stone. So now You can do just the same - ream more, fit bush in place and fit the stone in the bush.
    • The back when new would have been the same colour as the rest of the case as you can see very dark gun  metal is a very dark blue/black and would not be shiny. So unless the owner intends to match it how it would have been when new which  I don't think it can. It should be left as it is.
    • Why all the fuss? I just use a big eyebrow tweezer to grip it and it works fine. The eyebrow tweezer also works great for replacing Chinese Incabloc springs that fall out.
