Success! Sort Of...
Don
I successfully (mostly) finished cleaning, oiling and reassembling my first mechanical watch yesterday. I bought a beat up old Caravelle and three movements worth of spare parts. Unfortunately, I dropped the one good balance out of four and mangled the hairspring, so I had to use a backup. The watch sets and runs, but doesn't run well. Also, I switched the dial from the original to one I liked better without thinking to check that it would fit the case - it didn't. But I got it all back together, so I'm considering this a victory.
Before:
During:
After:
If you're observant, you'll notice that the watch changed from 7 to 17 jewels somewhere in the process. You'll also notice that I had a little trouble with the concept of reverse threaded screws. :growl:
these are all things you have to learn...usually the hard way like I did! If you are like me and never had formal training, your mistakes are burned into your brain and you never forget what you did wrong to cause them! I'm not saying they will not happen again, but usually not for the same reason....
Hang in there! it's so gratifiing when you get through an overhaul and the watch is running beautifully!
FYI-Also, you'll notice the screws with the reverse threads have 3 lines on the screw heads, This is usually a dead giveaway that they are infact reverse threads...
Well done - I'm on the same track but I've lost a **BLEEP** screw and I don't have any spares.
The reverse thread screw on the crown wheel got me too.
That's where Marks's videos come in handy - this reverse thread is mentioned in them!
Thanks for all the positive comments. I really love this forum. :D
DJW, you're spot on about making mistakes. Each one taught me something. It took me forever to figure out why the stem couldn't be pulled to the setting mode and why the train was locked up. Turns out when you use a ratchet wheel screw on the crown wheel, it doesn't work so well. I'll forever remember the three slotted screw thing too. Most of the setbacks were very enjoyable because I felt I was gaining experience.
Thanks Bob. I ended mashed the different movement parts together and ended up using the trail wheel bridge from a 17 jewel version. I'm not sure if I've got all 17, but the bridge says 17 jewels.
I've already got my next victim, a vintage Lucerne that is currently running slow. I'm looking forward to having the time to tear it apart and apply whatever I've learned from the first watch to it. When I get more confident, I'm going to have a go at a Stowa I bought 5 years ago and have been dying to get fixed.
I've got a used L&R PC3 ultrasonic cleaner. I used Zenith Hi-Tech cleaning solution and Zenith Hi-Solv for the rinse. I couldn't find much info on the Zenith products as opposed to the L&R solutions, but I chose the Zenith because they are advertised as low odor. So far I'm very happy with it.
I'm a little ashamed to say that I didn't read the warnings on the container, but I assume there is some risk of ignition, especially with the rinse, since it evaporates very quickly. The smell was not bad at all for the cleaner and rinse, but I also bought some hairspring cleaner from Zenith and that stuff smells pretty potent.
Hi Don,
Re the 7 to 17 jewels things...?
Are you going by the sloppy stamping on the train bridge? I think that its a legit 17 jewels as the 'seventeen' would have been there from the beginning... just a bit of carelessness.
Anil
Hi Anil,
I had parts from three movements. The one I started with was a 7 jewel version. I ended up using the main plate and train wheel bridge from one of the others that was a 17 jewel version. In the "before" picture, the train wheel bridge bearings are not jeweled.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
