Watch case repair.
Hello, first time here.
I have a watch on it's way, it is not a very common watch it is a Rado Blue Tiger from the early 70s the case is made of corundum (sapphire) and it is missing a piece between the lug in the back.
Any suggestions as to what materials to use to fill the space.
I was thinking maybe epoxy or JB Weld.
Thanks.139e56e09d44dbd9ccd286f3884df2ae.jpgcec72292383a58c53fd6f0d64e68d0bd.jpge388852100096e24599636ac55c60b77.jpg
Sent from my SM-G920P using Tapatalk
I think you're spot on with your suggestion of JB Weld.
You may need to do a couple of thin layers rather than trying to get it filled in one go. JB Weld is then easily sandable once dry so with some fine wet-and-dry sanding paper you should be able to achieve a good finish. JB Weld will however dry a dark grey so you'd have to find a 'midnight blue' (enamel) paint to best match.
Thank you.
Wow.. you got lucky here as the break can be disguised. These cases tend to crack in two if they are dropped!
Good luck!
Anilv
Thanks, yes I got lucky you don't see to many of these watches around and they are almost impossible to find in good condition.
I was lucky the other day and found a green one NOS.9224fadad14b9fc90fe482eb02c63f49.jpga70364660905e90ed7890bdedf7cdcef.jpg
Just as another quick tip...
If you refer to your second picture you're clearly going to want to create a nice straight and clean edge as easily as possible. If you can get hold of some vinyl masking tape - usually called fine line masking tape at model shops - then you could pull a piece taut around the edge of the watch to create that. Crucially if you cut a small section of this tape and reverse it where the repair is - so the non-sticky side is where the repair is but the rest of the tape holds it in place - then this should peel away once the JB Weld has cured to leave a lovely straight edge. [You could of course probably do the same with any smooth tape but ths vinyl tape sprung to mind as a good choice].
Great idea, I will give it a try.
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
