I need to find a donor movement (looking for a balance wheel and staff). Can you help in trying to identify the movement? It's a large size pocket watch with not a lot of info to go on I am afraid. The movement itself measures at 53.77mm.
Y9wz8R0.jpg?1
NXOHmJZ.jpg?1
TKCzof4.jpg?1
ABTrrVr.jpg?1
Ew7i4UY.jpg?1
UZQhX6s.jpg?1
Any help or leads would be greatly appreciated.
It looks like a common Swiss bar movement. These are tough to attribute to anyone, especially  when they are not marked with anything other than something generic,  like this one is on the dial. Maybe if one had access to Kathleen Pritchard's book on Swiss makers, one could identify it, but that book is pricey, rare, and may not be much help. I wish you luck on finding out the maker. And once you do, who knows how interchangeable the balance will be. Best of luck on your project.
So far I have been advised that the "ancestory"" is a fontainemelon (FHF) movement of some type that has been modded to resemble a "Jules Jurgenson" bridge type. So now I need to find the exact caliber it's based on. I have included some sizes in mm and inches (not sure of the lignes) and I am hoping someone with a "Best Fit" book might be able to identify the caliber it is based on.
The shoe shaped bridge in the keyless works (photo above) is definitely similar used on the FHF 18.5" H5 bidfun-db Archiv: Uhrwerke: FHF 18.5'''H5 Lepine  *
* Big thank you to Hartmut Richter for this information.
53.92mm works out to 23.9 lignes, or almost a 29s......not sure if this helps or not....
Edited by khunter
math correction
Thank you. Everything helps.
what does the "s" signify in the "29s"? Is that an American measurement?
s is for size...as in 18 size, 16 size, etc.....yes it's American
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
