Rolex 3055 Hour Wheel Seating
GeorgeC
Thank you but this is for the rolex 3055 that has separate day and date indicator discs.  I believe that the round flat washer I am speaking of goes on top of the day of week disc then the dial on top of that.
I have put the watch back together but when the day/date changes at midnight, I don't get the full kick over to the new day/date like the watch should.  Just second guessing myself on the hour wheel seat and whether I forgot exactly where it should be placed.   If there are other suggestions on where I can look on the date change issue, please comment.
Thanks
Thanks for the link to the tech manual.  I really couldn't read where the hour wheel seating was to be placed from the all of the text instructions.
There are 4 variations of thickness, thus 4 different part numbers listed 5123-1 5123-2 and -3 -4.  As shown in the picture, flat and thin.
10 minutes ago, khunter said:
In the disassembly section the wheel comes off then the seating. On page 16 the seating goes on, then the wheel after lubrication. In your first post you said hour wheel, not date, which is why I thought you were talking about the dial washer.
Ok disregard all of this......i read and re read and finally figured out what seatings they are talking about. You are correct, they don't say where the HOUR wheel seating goes, but from what I can tell it must go between the wheel and dial, to have the correct endshake which they do specify as .03mm. Im not sure if that is causing your date jump issue though as they describe increasing and decreasing tension on the jumper spring to correct it.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
