New machine for the shop
measuretwice
I just finished painting this and thought you guys would get a kick out of it.  Its a Hauser M1 watchmaker's jig borer.
I normally worry about getting my machines in good mechanical shape and don't care about paint (if you're using them, the paint will look like crap after a year of chips and coolant in any event) but this little one was worth it.  Its primary used by watchmakers as a jig borer and mill.    Its direct reading off the dials in ten thousands of an inch with lead error correction (the marker for the dial moves and follows a profile to correct for any screw error).  Now it is a jig borer, but I'll say it is the nicest machine I've put my hands on, and that includes many of the worlds best names including other swiss stuff.  Exceptionally well made.
i bought yet another mill and lathe before Christmas and ended bringing this one home as well, they don't come up often and it just too cute.  Wear is negligible with the original scraping well defined everywhere.  The only flaw was the paint was literally falling in big chips - another good reason to paint it.  I chipped all the old paint off, it was so thick, feathering it was a real challenge, so just took it all off.
I have the spindle (8mm collet) and drill gimbal but I'm going to have to make the microscope.  Used for locating, the microscope is an important accessory as they are also used as an very toolmakers microscope.
I have the original stand, but no room for it at the moment.  They powered these things from a motor hanging from post, much like a foredom.  The ideas was to isolate the machine from vibration....not sure yet how I'll go about it but I've some ideas
Edited by measuretwice
9Vphc58.jpg&key=76b9a0c88cb9d0b095f0d0f5987ba258222ff216884641ec46f0d5c0477a302e
uvxKHfs.jpg&key=16860d947c2a8f295da54e050771eef64ccfa9fd1cba156c332f232f9d5f10dd
gLz7BWm.jpg&key=058c85bb9aa5283cac1c6f1de36b5010628e066e48dfcaf1422faf32bc975066
That’s nice I bet it’s heavy well done
looking cool is its main function  :).  A jig borer is primarily used to make holes - very, very accurately placed holes.  It can also be used for light milling, which anything in watchmaking pretty much is.   This particular  machine is highly favoured by watchmakers because of its small size and accuracy.
Of all the machines I've got, it'll probably be the least used, but I like the tools and its been on the wish for a long time.  The law of diminishing returns has definitely pushed this toolaholic way out on the skinny side of derived utility, but I'm still having fun :)
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
