Chime gears
RockyRR
Ok, folks, this is my 1st post and I need some help.  I was given an old mantle clock (an Ingraham according to the winding key) that didn't work.  I now have the clock ticking with its pendulum.  However, when I turn the hands to make the chine hammer strike, it only does it once no matter the time.  Even when I lift the bar (blue arrow in picture) it only moves one "notch" (see red arrow).  I expected it to go from one shallow notch to the next until it got to a deep notch.
Any help will be appreciated.
Thanks,
Rocky
I’m going to use the same terms as show in the video so as not to confuse you.
The worn stop lever (blue) needs to sit into the cam wheel slot, the green lever should lift from the counting wheel (make sure the green lever is free to lift out of the counting wheel. Make sure when the blue lever starts to rise so the green lever should also rise. When the count wheel moves from tooth to tooth the blue lever must be high enough to keep turning, only when the green lever falls in to the longer slots of the count wheel should the blue lever drop into the slot of the cam wheel. On the warning, the yellow worn pin should be at about 45 to 50 on a dial face. It should be at that position before the warning starts, make sure the hammer does not start to lift at that moment. This other photo,  I have marked in red this wheel has a pin that that engages in the teeth of the count wheel which moves the count wheel forward.
I hope I have not confused you. Keep me up to date. I am here to help. The strike on American clocks is not easy to understand, with it having so many levers.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
