Four Watches For Me - And All Free
WillFly
A member of another forum was giving away 4 watches - 3 HMT Indian models and 1 Chinese - to the first person to get in touch with him. All runners, no guarantees - perhaps NOS. So I jumped in - and I get them tomorrow (I hope). No straps or lug pins, but that's no problem. We'll see what they're like...
They arrived this morning - simple but OK and in very good nick with just a bit of wear and oil here and there. Pics:
First the Chunlei:
The HMT Kohinoor:
The HMT Suraj:
The HMT Vijay:
Edited by WillFly
Very nice. Like the Vijay.
BTW whats up with the Chunlei? Did you adjust it that far? Was it running way too fast?
I haven't touched it as I just wanted to see how it's running. It was wound and set at 10am'ish this morning and is spot on to the second as I write this (10.46pm).
I ordered some cheap straps for the freebie watches and they arrived this morning. I'm contemplating putting at least three of the watches on eBay (the fourth one - the Vijay - has the rogue case back...). However, if anyone on the forum wants one for a tenner plus postage - either as a keeper or to tinker with - I'm happy to oblige. I'm going to give anything I make on them to the Spina Bifida Association. (I had a younger brother who died from Spina Bifida, age two months, so it's a cause I support).
First comer via PM, first served.
Edited by WillFly
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
