A simple screw...
Pip
I’m sure this is a very easy one but I’m damned if I can find the answer so thought here would be the best place. There’s no such thing as a stupid question and all that...!
Anyway, been working through a junk old pocket watch. Got it done now (I think) BUT of course the dial is broken and one dial screw is missing too.
My questions are: What screws do I need to order from Cousins? Are they a standard size thread? And do I get bigger head screws or tiny washers? Or just order a new dial? You’ll see what I mean from the pics.
Shot of dial and close up of one side of damage:
Pic of screw on Dumont No2 tweezers and close up:
Thanks for your help!
Pip
Hi Pip, dials usually have feet or posts which go into holes in the movement. These feet are then secured, usually by a sidescrew.
In you watch I believe the feet broke off and someone in the past has used a screw to secure the dial. If you can get the feet replaced the damaged can be visually repaired by some epoxy and white paint. Not perfect but not immediately noticeable as there is very minimal damage to the minute track.
Anilv
Thanks. Is that always the way as my case seems to be built with threaded holes just where the screws go. I’ve packed up for tonight so will check tomorrow but they don’t seem like add ons iirc. But you’re right in that every dial I’ve dealt with so far (all wristwatches admittedly) has dial feet of some kind.
Dials screwed to the movement  from the front are uncommon but not unheard of I have two Jaeger pocket watches with dials  that are screwed to the movement from the front but this is obviously not a good way to attach enamel dials as chipping would be a problem if extreme care is not used, screws are not usually of a standard set size in cases where I have had missing screws I have a large stock of scrap movements and have usually been able to find a suitable replacements. Buying a replacement pocket watch dial from Cousins is not a option you have because no one makes them now.
Another option you have is to use dial pads which are small adhesive dots that can be used to fix the dial to the movement.
Scaling from your photo of the screw on a Dumont pair of tweezers I estimate the thread diameter to be 0.6mm. If this is corect PM me and I shall mail you a suitable screw. The best way to repair the damaged enamel is to use white UV setting nail varnish now available everwhere and on eBay. You set it in sunlight or under a cheap UV light as used for detecting forged banknotes. Even less expensive UV LED chips can also do the job. Cousins sell a similar UV varnish for dial repair but at 10x the cost.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
    • Yep, that's exactly how it should fit. The reamer shank is tapered and the socket in the spindle is also tapered so that the one centers in the other and is gripped tightly. If there is any wobble when the reamer is seated as far it will go then there is a problem. The cross hole in the spindle is to allow you the push the reamer back out again. If the reamer seated much deeper then it would limit the access for pushing it back out again. Here is one of mine for comparison.
