I've done numerous overhauls involving KIF trior, elastor and Ultraflex, as well as the Novodiac systems. I have done many many overhauls with Incabloc. This particular ETA 2671 has given me a very difficult time. When I unlatched it from the mainplate to clean the jewel it immedialtely sprang away which is not supposed to happen, and indeed has never happened with other incabloc shocks I have unlatched. I've broken a few in the early days, yes...but they don't just  bounce freee upon unlatching. OK, so I recovered the darn thing and figured out how to secure it back onto the plate, but it slides out quite easily. Worse yet, I CANNOT get the arms to bed down far enough, and inward enough to secure themselves! I have tried everything I know: cling wrap and using a clean metal oiler, holding it with rodico and  super fine brass tweezers, using needles that have the points filed down, removing the endstone to see if maybe it just needs clearance to secure...nothing works. It doesn't matter if the stone is in the setting or not. The longer I try the more I fear I will simply break one of the arms off as I continue to try to push it simultaneously inward and down far enough to catch. Could it be deformed or something? I've stepped away from it because it is already a couple of hours and my mind is separating fropm reality at this point! Please excuse the pictures and yes the jewel and spring are dirty at this point.
J
Well you're asking us if it's deformed. Is it deformed ? You're the one that could answer that... Don't you have a similar spare to replace it with ? I wonder if it's not slightly bigger than it should be... I do know that these existed in various sizes, right ?
This is the spring that was secured in the movement, but I don't know what is going on. I doesn't look deformed to me. It lays flat if I take it out and the arms are where they should be.  I asked here to see if anyone else has had this issue with ETA incabloc spring in this particular caliber. I know there was a posting last year about someone that had a similar problem, but they managed to get it to latch. I guess I will continue trying until it breaks or locks. It is no use as it is (unlatched) right now anyway.
J
I would put the movement into a transparent zip lock bag, or at put some transparent plastic over the movement and use that to pressure the spring downwards and then just use the tweezers until I get it working. It's how I sometimes deal with stubborn incabloc systems.
Edited by Chopin
Chopin Thank you!  I can't believe it, but I had the spring backwards in its setting! Its a wonder I didn't break it. After answering your last post I thought "maybe I reversed it and now think that its correct." Maybe I'm getting too arrogant or cocky in my skill level by thinking "oh of course I know all about shock system...blah...blah..blah...." I should have realized when it was sliding out that it was incorrectly positioned. I am humbled now. Thanks again Chopin for dislodging my thinking out of its default mode.
Feels good to be human!
I wouldn't go any further yet. See whether a replacement spring is available for this calibre. It may of had a incorrect size fitted.
Even if you do manage to fit the spring with force, it may be so great on the top cap jewel that the shock protection system is not functioning. Those jewels need to move incase of impact to protect the balance assembly
Arrrh you've just solved it
43 minutes ago, Tim said:
You do know the two balance cap jewels usually have a different thickness, yes?
Yes I do. The balance cap jewels were not swapped out, however.
J
    • Hello and welcome to the forum, the best path to take is to get some medium priced tools , look at Cousins UK . They are a material house and are open to all. There medium priced screwdrivers are middle of the road and wil if looked fore serve you well into the foture I have added a little reading for you to help.  TZIllustratedGlossary.pdf Watch_tools_tipps.pdf
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
