K & D 600 Staking Tool set Questions
Gary
Hi Everyone!
I’m looking at a K & D 600 Staking der and was wondering if I could also use it to replace some jewels in a few watches I have? Not sure that it will multi function? It is missing a few pieces probably about 15 to be exact.
I have a few watches that need broken jewels removed and replaced.
As always thank you for your time!!!
Best,
Gary
Hi Everyone!
Best,
Gary
Staking is usually separate than jeweling. The forces and precision needed are very different in each.
Having said that, both sets come with adapters to cross over work. I believe the 600 may not have the micrometer needed for jeweling.
You would have to figure out what size jewels you need to replace to figure out if the pushers in the set are there or missing.
If you have several movements that need jewel replacement and plan to do more such work in the future I highly recommend the Horia tool.
What would work great is to make sure you're buying 4mm staking set so that you can buy the plain 4mm Horia and use the K&D pushers and anvils.
Cheers!
Cheers!
Thank you! I wasn’t sure if all the differences but thought I may be better served by a jeweling tool.
Thanks again,
Gary
Thanks again,
Gary
Sure thing!
If not going the Horia route, then the Favorite is great followed by the Seitz.
Good luck!
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
