hi, i am from philippines and i would like to ask for help in finding a crown and stem for this type of watch, where can i order parts for this ?
i have tried different watch repair here, but no one seems to give how long should i wait for them to order the parts for this watch,., thanks
Honestly I would say that the only way for you to source these parts is by sending it to Breitling or trying to contact them and see if they actually offer parts to customers (which I doubt).
One other way would be to take it to a watchmaker that can order parts from breitling.
Sending it to breitling will not help much :) As it is a Tag heuer. Movement is a ETA G10 so the stem you could find from a watchmaker or maybe Ebay. It harder with the crown i think. Tag heuer supply of crowns a small. Try Cousinsuk as the have some crowns for Tag heuer. Or try contacting Tag and ask if the have any repairer in the Philippines.
Good morning from Bk, NY. You can get the stem from Esslingers
https://www.esslinger.com/genuine-eta-replacement-watch-stems/#&gid=1&pid=1
The movement os G10.211 with date at 4: https://www.esslinger.com/eta-watch-movement-g10-211-quartz-movements-date-at-4-00-overall-height-7-4mm/?utm_medium=googleshopping&utm_source=bc&gclid=Cj0KCQjwpMLOBRC9ARIsAPiGeZAjD1Pcml4HY3QmMw6D7wGnXZ17hZzLiqoIa5XZChceiSrutNpqQFIaApdxEALw_wcB
The stem is ETA 401-1497. For the crown, you have to measure diameter. Esslinger also has many, but not sure if you can get a black one.
J
Edited by noirrac1j
typos
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
