Broken Pinion
Vich
Finally got round to taking my Brother in laws Rotary apart to glue all the chapters which had fallen loose back on. Unfortunately when I went to put the very small pointers back on to the chronograph dials I realised that they both still had the ends of the pinions still inside them and I had sheared them off when removing the pointers. The movement is a Miyota and I will get another but anyone know how to get those pinions out of the pointers the hole is smaller than anything I have and there is little or nothing to grip. The pointers themselves are only 3.5 mm. I am starting to think I should just get new pointers.
Cheers Vic
I am having second thoughts about this now.  Looking at the myota 6P50 pictures on the internet there are actually no projecting pinions.  I am now wondering whether there is too much glue on the back of the dial holding it too far away from the movement.
Either that or I am just being cack handed.
Hi Vic,
Are you sure it's a 6P50?  I don't see that movement listed in my list of Miyota Tech Specs, but I may not have a complete listing.
I did find this one (PDF Attached), that looks like your movement, the Miyota 6P21, and there are definitely pinions for the hands.
I hope this helps mate:
Miyota _6P21.pdf
Cheers Lawson,
I got the PDF for the 6P50 from the Cousins download site and I have the old one I knacked up which is marked. There are a couple of places that sell them but I am waiting for my preferred supplier to return from holiday as I am not in any rush.
I know now why Mark seems to use two levers instead of the presto style tool.  The pinions are apparently .17mm diameter and I am 16 stone - no contest really.
I had a look at your PDF which is better in layout than the Cousins one and similar enough to verify the problem.
Thanks for the help.
Vic
    • Maybe I'm over simplifying this and I'm a little late to the discussion, but just by my looking at oil when I use it on a treated cap jewel  the oil stays in one nice bubble, but when I don't it spreads out to the edges of the jewel. I'm not sure (but could well be wrong) but the analogy of a waxed car and rain is accurate in this case, the wax is very hydrophobic and repels the water, however, the process epilame works by is a different physical process based upon cohesion/adhesion (oleophilic) not repulsion (oleophobic)  at least as far as I have read/observed. If one were to use a oleophobic substance equivalent to wax (hydrophobic) then one would need to create a donut shape to fence in the oil, however if one used such a strategy with a epilame which is oleophilic then the oil would sit on the ring of the donut and not in the 'donut hole', exactly where you don't want it. Even if the oil is smeared then the oleophilic epilame should pull it back to the center (see diagram below). Reference
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
