It is unusual for the jewel to ware they tend to either chip or crack. A picture would help also the movement and caliber will be needed.
7 hours ago, justin457 said:
i have a watch that has a dent in the sapphire jewel that the pivot wore a depression in and it doesn't look like i will find a replacement cap jewel any advice ?
You can grind it flat with diamond paste or powder and oil on a sheet of glass.
4 hours ago, justin457 said:
it is a harvey watch and where would i get the diamond powder and what grit to use
I am using these chinese pastes sold in 5g syringes. Under 1 USD per piece lol
Get the 0.5 and 2.5, the latter is the coarse, use this first and then polish with the other.
The jewel should be changed. After grinding the pivot fitting will be incorrect.
If you require diamond powder (mix with oil) I use Bergeon with 3 different grades & I purchased from Cousins.
I do agree that the cap jewel should be replaced, but if the jewel is set in an incabloc type of fitting, you could get away with lapping out the blemish and polishing the jewel.
I say this because the the jewel will be held down by the incabloc spring ensuring that the jewel is seated correctly in the setting.  This in turn will ensure that the original end end float is maintained.
Geo you could be correct, however the original post is not specific as to where it is worn to be 100% sure it is possible. Personally I think it is just not worth the risk & time required so I would just change it (if I could find a replacement that is)
5 hours ago, justin457 said:
the cap jewel is not a incabloc setting it is the old pocket watch cap jewels
Forget re-finishing the old jewel, you will need to find a replacement.  I can think of a way around the problem, but it would be a bodge so I won't even describe it.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
