watch repair business
Good afternoon everyone,
I have a quick question and was wondering if anyone who runs a business could help? If you do this full time for a living do you run your business out of your house? If so how did you attract customers? Also how did you attract jewelry stores so that you could take on their watch repairs? If you started out working out of your house and moved to a store front, when did you realize it was time to do so? Also if you started out part-time like I am and have moved to doing it full time, when did you know it was time to start working on watches full time.
Thanks
Technically I don't run a business but can attest that a blog will result in inquiries from potential customers.  I work out of the house but have noticed that a proper workshop makes much more sense.  You're constantly chasing your tail to keep a movement clean and tidy if your working in a place with wall to wall carpet.
Boy would I love to work on watches full time.  If anyone can answer that last question of when to take the leap I'd love to hear it!
I ran my own business. I had a workshop within a shop that sold antiques. It was a full time job, in fact I worked longer hours as there is so much more to do. I was already well established in the town so had no worries. Only you can decide if it’s the life you want, I can tell you I never looked back, I was married at the time and my wife and I made a good living. If you are inundated with work then that is a sign to get into it full time.
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
