Clock Oiling
Folkvisor
Cause it is that is one of the many reasons why there are so many lubricants about. You never use a thin oil on a clock train. You do use watch oil on a clock with a platform escapement and I would suggest a pocket watch train oil.
The bell doesn't ring very well because the beater dampens the bell when hitting it.
Is there a way to remedy this?
It is called a hammer that hits the bell. Bend the hammer closer to the bell; it is a trial and error until you get it right. If you have the movement out of its case, it will sound different. Cases were designed in a way so the sound of the strike or chime could sound loud and clear to the ear. Modern clock cases are not, the type of wood also plays its part.
Will do. It's called a hammer for orchestral bells too.
The hour chime is a very nice full sound but that hammer seems to hit the chime then immediately drop away.
Between the bell hammer and pendulum length adjustments It keeps me busy. A work in progress.
Thank you for your advice.
This is a sign that the chiming wheels are not in line with the clock chiming mechanism. Is there any way you can take a few photos so I can point out what you need to do. The other thing do you know the type and make of the movement?
  • 2 months later...
Welcome aboard Dave.
Thank you for the post, it's one I've meant to make for a while now.  I too have been using fully synthetic engine oil for lubricating clocks for years now and have had excellent results.  The dregs left left in the new container from one engine oil change will give you enough oil to lubricate many clocks.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
