Valjoux 7734 30mins to 45mins
Thanks Frank
i found the info also, finding the parts will be harder (at a decent price)
8000/3 bestfit X5942 Chrono Seconds Gear
8040 bestfit X5944 Chrono Minute gear
8120 bestfit X5924 Sliding Gear
53 minutes ago, praezis said:
You will have to change the min. recorder wheel (from30 to 45 teeth).
But adjustment is more delicate.
Frank
Yeah, looking at the tech sheet it seems like the only work needed is to swap out the 30 minute recording runner (8020) with a 45 minute recording runner (8040).
I've never done this myself.  Be sure to let us know how it goes.  :)
Looking on Cousins they list the sliding gear with a 45 minute version also #8120
as other places also list the 8000/3 for a 45 min conversion too (listed at the bottom of the parts guide)
its all adding up to $120 so far
Ah yes, good catch.  It looks like the sliding gear changes from part 8100 to 8120 and the chronograph runner changes from 8000 to 8000/3.  It makes sense why the sliding gear would need to be changed...  I'm hitting my post-caffeine wall though which is causing me to scratch my head when it comes to needing to change the chronograph runner.  Probably it just has to do with tighter tolerances.
Glad you've had your glasses on during this exercise though.  Best to figure out all the needs upfront than to be surprised later.
I don't think I can claim any prize for that one - I just reading forum posts on websites and typing numbers into search boxes :)
At least you know what they I do, I won't know that until I have the old parts (30 second) in my hand - or until I have analysised it properly :)
Very grateful for your help
cheers
dan
I have found the parts, luckily in Europe so I don't have import duty to contend with
I have been checking the service guide PDF, I see what is meant by setting up, I am excited by that, it looks like a good challenge
I believe its these parts
I will post images - maybe a walkthrough,  when i do it
  • 2 years later...
  • 3 months later...
    • This is not rare at all, the dial code and case code don't usually match.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
