I have question regarding cleaning an automatic watch. Is it ok to clean the bidirectional wheels as I seem to remember seeing on an ETA assembly diagram the instructions do not wash. As I clean my watch with an ultrasonic cleaner will it do damage.
I have found where I read this it is for calibre 11 ó´´´ ETA 2836-2.
It recommends no wash & replace if dirty. I therefore presume other calibre's are Ok for normal cleaning procedures.
I've not worked on one before, but what harm could it do? Surely it would be better to clean and reassemble than replace in a non-lubricated dirty condition. That's what I would do unless someone can give a really good reason not to.
I would be interested to here Mark's take on this.
Geo,
I agree but it does seem strange that this particular ETA movement has this advice on their tech sheet. Perhaps these wheels are constructed differently  or made of material that can easily be damaged when cleaning. I have cleaned other calibre ETA  movements with auto and had no problems after.
I'm taking an online class about watch repair sponsored by Otto Frei website and WatchZone. The instructor used to work for some Swatch or Swiss name brand as a watchmaker.
The movements used are the Unitas 6497/8 or ETA 2801-2 and later the ETA 2824 (can be substituted with the ETA 2836-2). The ETA 2824-2 is the same as the ETA 2836-2 without the day ebauche. In this class, we are supposed to clean and lube all these movements (we use ultrasonic cleaning machines).
Considering the initial question here, and the understanding that -- a difference from Asian markets -- Swiss watches are designed with servicing in mind, I'd definitely would like a second opinion!
PS. Mark has a video servicing an ETA 2824-2 which is outstanding -- I would apply the same logic to the ETA 2836-2...unless the contrary can be determined (here?)
The official ETA take on this is that you do not clean or lubricate the reverser wheels, but replace them.
The reason for this is that when they are new they have a factory applied lubricant which keeps thing moving nicely without gumming up.
The problem with cleaning them is that they then need re-lubricating, and the issue there is that if the wrong oil is used, or it gets into the wrong places, the pawls stick.
However, if my budget doesn't allow for replacement then I am quite happy to put them through the cleaning machine and then very carefully lubricate just the pawls with the smallest amount of 9010 that I can apply, and this works for me.
There is a special lubricant that you can use called Lubeta V105. This is a waxy lubricant dissolved in a highly volatile carrier. You simply drop the wheels in and then take them out again. The carrier solvent evaporates and leaves behind a very film of the wax.
The DIY version of this is to mix 9010 1:10 with naphtha.
I haven't tried either of these techniques but those who have reported their efforts on the inter-web report favourably.
Excellent Marc, I've heard of the Lubeta V105 but I haven't yet searched for availability from the suppliers I know. Since I'll be servicing some 2836s in the near future (they are waiting for their turn at my bench) I might opt for the lubeta lubricant.
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
