Question about Illinois 6/0s
Gary
It looks like you will need a wide bifurcated screwdriver to tackle this one.  That is a screwdriver with a notch slightly wider than the threaded screw in the centre of the nut.  Being a special, it's one you will have to make yourself to ensure a good fit.
