My brother had the battery changed in Goldsmiths about a month ago. Doubt they caused this but I'm miffed at the damage to the caseback.
Anyhoo, when my brother pulled out the crown to adjust the time today, the whole stem came out.
My tool kit doesn't have a case tool with a thin enough blade to open it. While I order one, does the stem look worn/damaged (still adjusts time & date) if not, what do I need to re-seat it?
Thanks, Rob.
If the case was pristine to begin with that damage is shocking. At least with it being stainless steel, you can re-finish it quite easily.
First battery change in its life and bought new.
Will refinish after if I can fix it for him.
What the HELL!
Why can't I find a case knife with a thin enough blade to open this?
Maybe that's why they scratched it up, resorted to using screwdriver or something.
Get one of these, they have a narrow width at the tip and you get a lot of leverage and control. I have used one for a long time now with great success.
http://www.ebay.co.uk/itm/Watch-Back-Case-Knife-Opener-Remover-Watchmaker-Jeweler-DIY-Repair-Tool-Orange-/231269195527?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item35d8b7df07
Hey Geo, how thick is that tip as I have a similar one and its too thick for this particular case back.
The only thing I have is an old razor sharp 2" lock knife and no way am I using that. Probably end up in hospital, again. :wacko:
Grind the tip of the back opener to fit the slot. Just make it as thin as you can get away with, without turning it into a razor edge.
Ok, I'll dig out the dremmel and modify the one I already have.
Being right handed, I hate my dremmel, wish it was reversible so as to avoid shrapnel in my face :angry:
Right, finally got it open. At least they inserted a Renata and not some cheap brand.
Anyway, can anyone tell me what bit holds in the stem.
Well done. If you ave a look at the area where the stem goes into the movement. There will either be a small button or a lever press, I don't think it will be held by a screw. I have not worked on one of these, so I may be wrong.
Found it using loupe. Just above the H of "Push" is a hole. Under it a lever appears when stem is all the way in.
I think either the part that holds the stem or the collar on the stem itself must be worn out.
Movement is Time module SII VD57B. Will try and find a pic of replacement stem and compare it.
Hi Rob, I was looking around and I haven't been able to find any reference to the movement and/or the stem numbers. On this side of the pond they are, apparently, discontinued!
Thanks for looking.
All I found is the manufacturers site showing tech diagrams etc.
www.timemodule.com/sii/index.php?route=product/category&path=0_62#product_VD57
there's nount wrong with the stem, I would suspect that whoever butchered the case back, then merrily prized the old battery out with a screw driver & bent the top plate dislodging the stem lock.
the area circled in red looks to be damaged/scratched to me???? if so then this is probably where they tried to push things together again
I would start by giving the area cirled in black a little push down. OR take it back armed with what I've said & get them to replace the movement at their cost!
Lee
Edited by Lee
Now don't get me wrong I could be way off base & totally incorrect but what I see in the picture & your fault, suggests to me..............
There's a little clip that releases the battery bridge "A" I'd lay money down they haven't used it, instead stuck a screw driver in somewhere in the area of "B" and forced the battery out causing the top plate to be damaged, which by pushing back down they've thought they got away with!
I bow to your waaaaaay greater knowledge, expertise etc.
I'll speak to my brother and see what he wants to do. He may ask me to try to remedy as per your suggestion but I want his go ahead.
It was about a month back that he had the battery changed. Wish I had checked the caseback before and after while infront of the assistant. :angry:
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
