Hi Folks... Newbie here...
I'm searching for info about wristwatch diagnostic software suitable for a PC or mobile phone.  I've been trying to verify the regulation on a couple wristwatches and  have WildSpectra Mobile (Lite and Pro) installed on an Android phone.  Despite my best efforts, I cannot get it to read reliably for longer than a few fleeting moments.  My watches are running within 10s/day but, I cannot get the software to lock-on long enough to get a reading that seems to confirm reality.  I've tried all the recommendations that accompany the software and am chalking this experience to yet another instance of frustration caused by cell phones and/or the generally poor software that runs on them.  If anyone has any clues, I'm still willing to give it a shot.
Is there any PC-based software that might be less frustrating?  I happen to have some high-end audio recording mics and a 16 input Scarlett audio input mixer along with Scarlett Studio mixing software.   I've seen a program called Watch-O-Scope but don't know if it will work with my mics or interfaces patched-in via USB.   Is there any other software that might be suitable for basic wristwatch analysis?
Thanks in-advance for any tips or leads that prevent me from installing 10 software packages only to find-out that 9 weren't worth installing.
Ray
Edited by RayCJ
fix word flub.
There is a ongoing topic in this forum that a member has written some software and designed a pre-amp for the PC.  If you look around you should find it. Last post I saw was in early March.
Thanks everyone for the ideas.   I'll do more investigation.
I was thinking of continuing to use Wildspectra and building an insulated box with a clear lid.  Maybe that will cut much of the background noise long enough for it to get a good reading.
Ray
On 4/10/2017 at 7:47 PM, RayCJ said:
  Is there any software that might be suitable for basic wristwatch analysis?
WoS has everything one would need.
No need for a preamp. Just a simple piezo and accompanied with software frequency filtering is perfect. Although, a simple preamp wont hurt.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
