Q&q - The Zero Jewel Movement
Hi Guys,
In my hunt to find new watches to practice on, I was given this watch to work on.
The Brand is Q&Q ... and it looked like a new basic movement for me to service.
Once I opened it up, I was shocked to see "NO 0 Jewels" stamped on the back.
Once I removed the movement and looked at the pivot and pallets ... this is what hit me!
PLASTIC!!
ROFL!  What a piece of junk.
But I thought I'd post it for your amusement :)
Plastic fantastic, I've never seen anything like it in my life. It reminds me of the small plastic gifts you used to get small cars in Corn Flake packets back in the fifties. They came assembled, but would break down into about eight pieces for reassembly.
Ah those were the days.
PS Does anyone remember the baking soda submarine? It was my favourite!
Geo,  What is baking soda?
Re. The plastic watch,  I am amazed that changing a few parts to plastic can have a significant cost saving, obviously it does else they would not have bothered.
Lawson,  If you take it apart and put it back together you will have gained some practice and if it all goes horribly wrong,  no great harm will have been done.   :thumbsu:
Autowind - I'm too scared to unscrew it ... everything is under one single plate.
I think it will fly into a million pieces if I pull to the top plate :P
ps. - I should mail it to Mark to video a service on it ... maw haw haw haw
Edited by Lawson
Wonderful stuff Roger, and I don't believe for one minute you don't know what it is.
I use it for blast cleaning carburettors, it removes all the muck then all you have to do is wash the carbs in hot water to get rid of any residual soda.
Here's some more uses:-
http://www.care2.com/greenliving/51-fantastic-uses-for-baking-soda.html
Thank you Will, that's an excellent link (and sub-links at the bottom). I was wondering if casting with one of those smooth-on kits will allow to build one! I'm currently preparing to experiment with the plastic gears in the Seiko movements I'm restoring.
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
    • Yep Mike , i use exactly the same gauge for it.
    • You definitely pick up different names from different people of all ages from everywhere. Like learning different dialects of the same language. Its all part of the learning curve of any trade.  Both those two terms describe to me perfectly that they are one and the same. After a couple of years of knowledge you can figure out what is being talked about. There are times that i get caught out with something i haven't encountered before.
