Hello all, recently I've noticed that my watch cleaning machine is not cleaning all the parts properly. I use zenith cleaner and rinse and a l and r manual machine. When I clean the parts I put the plates in the bottom and small parts on the top. I run for 5 minutes in the cleaner, spin off for a minute or two and then 5 minutes in each two rinses with spinning off in between. When I'm all done I notice a yellow Chem, I assume cleaner, on the plates. I wind up cleaning them off by hand before I dry it, I can't figure it out, what can I be doing wrong.
Sounds like there's a problem with your solutions. Maybe contaminated with something? I once noticed a significant change from having mixed them with a few drops of water.
Not sure of thebtiming of things. I usually leave my main washbfor 10 min. Spin until there's no visible fluid which is usually a few seconds and then go through 2 rinses.
I'd start with refreshing your solutions.
Cheers!
I would get rid of that cleaner in that jar. Wash the jar out and dry it and add new fresh cleaner and see what happens. Just a thought is there anything from the cover of the jar that could be leaking into the fluid.
I changed out the cleaner and added new, it seems like the placement of the plates in the jar are not allowing the rinse to get to them
Not sure what you mean. Jars not filled enough to submerge the whole cage?
Do your jars have baffles in them?  Each jar in my L & R cleaner has a baffle in the bottom which creates a bit of turbulence in the cleaner as the basket spins.  These baffles, along with reverse cycle, help clean around all the parts.
@jguitron is correct that water contamination will cause problems.  I'm pretty sure Zenith cleaning solution and water are immiscible.  Also, if your cleaning fluid hasn't been changed for a while then you'll also see a film build-up on the parts.
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
