Hello Mark, hello folks,
My first time post here and I hope you can help with my small issue, I have an Omega day/date with 1151 movement. It is working perfectly in general, until I noticed something is out of order with the chrono hour counter, the subdial at 6 o'clock. If I stop and reset the chrono to zero, it looks fine, but that small  hour hand seems to keep on turning, although very very slowly, for example, in the picture here, you can see it moved  30 degrees in about 48 hours, now pointing to 1. I was wondering what might be the problem here and if this is a small fix that can be performed by a regular watchmaker, as I don't want to send it to Omega for their pricey "full service" which they always try to convince you is needed.
Thank you.
With the chronograph stopped, if you press reset does the hour hand jump back to zero, I only ask as it could be something as simple as the hand is lose on the pivot.
Hi wls1971,
You know, the hand being loose was my first thought but it seemed to be advancing kind of regularly.
I just pressed reset and it went back to 0 (12).
It could be as suggested a loose fitting hand. However it will need looking at by a qualified watch repairer. Chronographs are more complex than a normal watch so require a lot of time to strip inspect & repair. If it is the hand maybe a easy repair but I have my doubts.
Have a  look at this video. At time 2:20, Mark assembles the hour counting wheel mechanism. The way the hour counting works on this watch is that the wheel is attached directly to the mainspring barrel via a clutch mechanism. When you reset to zero, the hour hammer spins the wheel back to zero and the plastic lock engages the edge of the wheel, preventing it from turning - and activating the clutch. I suspect that plastic part is worn. All in, it's a simple repair, but it must be done by someone that knows what they are doing!
5 minutes ago, wls1971 said:
Apparently this is know as "hour hand creep", and is a know problem with the 7750 based Omega chronographs
This is a explenation from the chronomaddoxx site
http://chronomaddox.com/tzof_faq.html#Chrono_Hour_creep
Also a very plausible explanation. Once the hour hammer resets the wheel, the hammer spring (which Mark is shown fitting)  is what keeps the tension of the hour counter lock (plastic part) against the hour counter wheel. If this spring tension is off, it would have the result previously described. Too bad they use plastic for this part. I suspect they do so to minimize the wear on the counting wheel itself.
Thank you guys, these were the answers I was looking for, I watched that video yesterday but didn't know what exactly I should be looking at.
59 minutes ago, SSTEEL said:
The hour brake is only plastic, and often wears, so replace this for new, and your good to go.
Ah, if only "I" could do it :)
Just to know for myself, in Mark's video assembling the calendar, is this the plastic stopper we're talking about ?
That's it!
So thats what it is for. When I service a 7750 I always did wonder what its purpose was.  If correct a very easy fix once the hands & dial are removed that is.
Yes thats the kidney, its mostly a plastic component, but on some other calibers it can be metal, seen these on some Omega's.
Edited by SSTEEL
Yep, I also learned that Omega has updated it in later versions of the movement, which they might install in case it's brought to them for service.
Anyway, it has been more than 36 hours since I last reset the chrono, and this time the hour hand has 'creeped' only very very little, perhaps half a millimeter, here is a pic of it, it might seem that it moved more than that, but the hand doesn't exactly reset right in the middle, but more like near the edge of the white dot, so apparently it  moves at its own whim :) :
    • Hello and welcome to the forum, the best path to take is to get some medium priced tools , look at Cousins UK . They are a material house and are open to all. There medium priced screwdrivers are middle of the road and wil if looked fore serve you well into the foture I have added a little reading for you to help.  TZIllustratedGlossary.pdf Watch_tools_tipps.pdf
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
