Hi to all, I am in need of some direction or if possible anyone who will know of this watch. I was given a international watch co watch,,
c.8541
1852723
schaffhausen
stay brite steel
1777673
803a
1/  what does that mean some i have figured out as i have waded through the net.
2/ it does run but the crown wheel and shaft if that is right pullout completely even after you reseat it and tighten the retaining screw
3/ the date indicator plate has a tendency to stick and i believe that this is caused by the plate that is screwed in place over the top of the date indicator, if i back the screws of it will turn but cannot think that they would be left in that way from the factory,
4/ in under the date indicator is a loose steel ring, it is held in place but it is not secured in any way bar, positioning points and you can here it tinkling.
any assistance is well appreciated, thankyou pd
Well you dont say what you have figured out so I will say what I know from the information you have given, your movement (1852723) was manufactured in 1967 and your case (1777673) between 1966-1968 so that ties in as being all original the 803a is the model number being a round stainless steel case or as IWC use the alternative name "Staybrite".
Thats a hell of a watch to be given regarded by many as one of the finest automatics produced, people will probably have a better idea of whats wrong if you supply pictures to better outline your description
Wayne
Edited by wls1971
Also worth noting this movement was often fitted with a split stem is all the stem coming out when you pull the crown or just part of it ?
Edited by wls1971
Thankyou so much everyone,
1/ stem is all one piece but what i can see is the groove where the setting lever locates ,the edges are all chattered and chipped.
2/ the ring under the date wheel is the disk door and this is what is making the tinkling sound, is this ment to be set firm or float around.I have not been able figure out what it does precisely.
3/ as soon as i am  able to get clear photoes i will load them up. I only stripped it down so far when i thought better of it and not just wading in.
4 The sites that were provided are very helpful and thanks all
the only thing i had figured was was the movement number, no idea for the rest of the provided numbers
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
