Thread size of BB crystal press? Need help.
Halvis
Does anybody know what threads the die holder of the BB crystal press uses? I got a press on ebay, and the threads of the die holder turns out to be badly stripped. The press is of no use as it is now, and a new die holder is difficult to source.
If I know the thread size, I might be able to get some sort of adapter that lets me use standard Bergeon/Horotec dies. Hopefully.
Thank you.
Count the threads on a good picture like the one you posted, and go from there.
BTW I think that no adapter exist, but with a great cost and effort, one can be made.
Edited by jdm
38 minutes ago, Halvis said:
I was hoping that if I am really lucky, I could find something like this with the right lengths and threads. Probably not realistic, but worth a shot if I know the threads.
As mentioned above knowing the threads isn't difficult but finding an adapter is impossible.
They are either M5 or M6 . On my sternkreuz press i have M6 . They are the same as on a Bergeon press?
Someone could probably pretty easy drill the old one out with a lathe and put a new fresh thread in. On the old adapter?
Maybe even clean the threads with a threading tool could help?
As there seam to be a lot of old material from the die left on the adapter?
Like this? schneideisen-hss_800x600px-2083.jpg.dbada6d5ea96329687670dd5a3d86ed1.jpg
Edited by rogart63
17 hours ago, Halvis said:
That is correct. The threaded part goes into the press itself, and the dies are snap on.
Then it's more difficult to say which thread the die has? You will have to take a look at how the thread in the press look also? Is that damaged to?
If so it could probably be saved with a helicoil thread? The adapter is more difficult?
I believe the thread in the press is steel and the die holder is aluminum, so the die holder has suffered the most. The female thread in the press is full of material from the die holder and it is difficult to get a good look without taking the press apart. I dont know if I should take it apart and clean it yet, because things are not resolved with the seller. Trying to find out what options I have.
I believe my die holder is beyond repair. There is a gap (marked in the picture) that's not supposed to be there. The plate is completely stuck and does not sit straight.Selection_055.png.f089ebe4a698572774ff189fcabfddd7.png
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
