Everbrite Watch
Sleeper
A picture would paint a thousand words "Everbrite" as a name has been around for a long time various watch companys have used the name and it is still in use by a company in china making cheap quartz watches. It has also been used by various companys as an alternative name for stainless steel when it first became popular as a case making material.
E.Ingraham , Westclox and A.Cohen and sons where early users of the name so it could have been produced by any of those companys
Well its a A. Cohen and sons these watches turn up with various names on the dial Crosby being the main one they where made to look like the more expensive American and superior railroad watches. The movement is Swiss, to find the maker and calibre number look with a eye glass just under the balance wheel there will be a shield with a symbol and a number.  From the look of it I think the movement will be a Unitas 431 the watch dates to around the mid 50's. The second hand is listed as a 0.26 mm for that movement
Thank you.  This watch has been kicking around my bench for about 3 years.  My wife found it in a box of treasures she unpacked and asked me to have a go at fixing it. No idea where it came from, she may have found it at a swap meet back in the 80s.  I cleaned it and it runs well and keeps good time. The problem it had when I opened it is the second hand had come off and wound up in the movement jammed in between the second and third wheel. No idea how it got there but it was fairly well mangled and unusable. Knowing it's a Unitas I might re-case it in a clear back case to show off the movement.
The small second hand saga goes on and on.  The shaft top is about 1 to .5 mm below the dial. Can't see once I put the second hand near the hole. The shaft is also slightly offset to hole.  I even made a jig to hold it in a case holder at a 25 degree angle so I could try and use my microscope.
I am wondering how long the shaft should be and if the problem is with the shaft, the watch dial or the height of the hand.
Might be lack of experience on my part.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
