Everbrite Watch
Sleeper
A picture would paint a thousand words "Everbrite" as a name has been around for a long time various watch companys have used the name and it is still in use by a company in china making cheap quartz watches. It has also been used by various companys as an alternative name for stainless steel when it first became popular as a case making material.
E.Ingraham , Westclox and A.Cohen and sons where early users of the name so it could have been produced by any of those companys
Well its a A. Cohen and sons these watches turn up with various names on the dial Crosby being the main one they where made to look like the more expensive American and superior railroad watches. The movement is Swiss, to find the maker and calibre number look with a eye glass just under the balance wheel there will be a shield with a symbol and a number.  From the look of it I think the movement will be a Unitas 431 the watch dates to around the mid 50's. The second hand is listed as a 0.26 mm for that movement
Thank you.  This watch has been kicking around my bench for about 3 years.  My wife found it in a box of treasures she unpacked and asked me to have a go at fixing it. No idea where it came from, she may have found it at a swap meet back in the 80s.  I cleaned it and it runs well and keeps good time. The problem it had when I opened it is the second hand had come off and wound up in the movement jammed in between the second and third wheel. No idea how it got there but it was fairly well mangled and unusable. Knowing it's a Unitas I might re-case it in a clear back case to show off the movement.
The small second hand saga goes on and on.  The shaft top is about 1 to .5 mm below the dial. Can't see once I put the second hand near the hole. The shaft is also slightly offset to hole.  I even made a jig to hold it in a case holder at a 25 degree angle so I could try and use my microscope.
I am wondering how long the shaft should be and if the problem is with the shaft, the watch dial or the height of the hand.
Might be lack of experience on my part.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
