My Phasar watch
Hello, sorry for the poor image quality but I can not do better .. I found this afternoon this watch in a flea market. It was given to me and changing the battery, I see that it works very well. As the photo shows, it is quartz with a black dial but also analogue-digital-alarm-chronograph and the movement has only this: VA41A And it is a PHASAR. So my question is: what is the model really and who manufactures this brand and what is the composition of the case because I can not find anything except on Ebay that does not have my model .. Thanks In advance .  :)
3 hours ago, frenchie said:
The movement maker seems to be a Morioka Tokei (maybe a seiko of some sort...)
example: http://www.ebay.co.uk/itm/Morioka-cal-VA41A-N-O-S-dual-time-watch-movement-/361892654803
You're right frenchie iforgot to mention it ' Morioka Tokei ' ..Thank you for the link . Could you date it ? because there's no date on it ..
Edited by SeikoWatch
phrase added
No, I can't date it... but if I were to take a guess I'd say late 80s, early 90s... maybe?
This movement is also made under the Hattori, Pulsar and Shiojiri names (search for hattori VA41)
example here: http://www.startimesupply.com/product/VA41.html
It takes a 396 battery and can be substituted with a v041 movement, by the same makers.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
