So I was given a Bulova watch from a friend and it needs a battery, the problem is there was no battery in the watch.  It looked like it might of been a 377 and so I tried it but it was slightly too big (battery) and too tall.
The movement says Bulova 7292-  tried searching and couldn't find a tech sheet or really any info.
Should I just use calipers and find something close?
Daniel
Did you try Energizer 392? It might fit. (Alternatively, 364 and 369 are one size below and above respectively). They all have the same electrical specs it is just the size that changes. Good luck, hope this helps.
Robert
Check it out but think that particular watch has a Miyota movement probably 98B-131.  A lot of those Citizen/Miyotas use SR927 which would be a Renata 399 equivalent.
Got most of the beers off your list thanks - most nutritious (:-))
Cheers,
Vic
slight addendum - if it is by any chance a Marine Star it would be a 364 or SR621 SW 1.55v rather than the bog standard Miyota type
 377 being slightly to big & to tall (thick?) leaves 379, 317 or 335 in order of popularity.
Hello Dan,
Had a bit time on my hands and judging by all the many and varied responses you got from me included I think we have successfully managed to cloud the issue.  I found yet another reference that suggests the 394 is the correct battery ! complicating matters further.
Given all that has gone previously,I still think that 98B-131 was correct fot the 7292 and if it is a "Marine Star" then here are two links, one will get the new battery for 5 Bucks and the other is a re setting data sheet for the watch.
Hope this helps and sorry if I have confused the issue.
https://www.bigapplewatch.com/battery.asp?prod=battery&watchnumber=BULOVA%2098b131
http://www.retrevo.com/support/Bulova-98B131-Watches-manual/id/24039dj893/t/2/
Cheers, Vic
Sorry for not responding sooner guys. Been a bit crazy here as I recently lost a friend and we are trying to help his young family.
Hello Dan,
Please accept my condolences and I wish you success in providing aid and comfort at this difficult time.
Regards,
Vic
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
